horn pad Problem
horn pad Problem
i replaced the shift column collar and the turn signal unit ,,i checked the horn by grounding it at the steering wheel with a screw driver and the horn worked but as soon as i mountedf the horn pad and then tryed the horn , it would not work?????????What is going on? Help!!!!
- ICEMAN6166
re: horn pad Problem
one of the reasons i dont like those wheels.
supposed to be a metal piece on the back of the pad i think.i am going out to the bus because i have to get a 72 column ready to ship so i will investigate the wheel and pad and refresh my memory as to the how and why.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
- rjewkes
70-72, and im' guesing 73-79 also have the same spring ring thing. And if somebody didn't know it when they removed it to fix the turn signal switch or to replace a broken wheel, it may have popped out.
if yours is missing or just the rubber pad part is brok it won't work.
fuelly.com
fuelly.com
