Radiator support removal
- 71Ford100
I can't get the radiator support mount bolts loose, I soaked them in oil any other sugestions other than getting them hot.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
- flyboy2610
re: Radiator support removal
And while letting the penetrant soak on the part, tap it with a hammer occaionally. The vibrations will help the penetrant work into the threads better.
An impact wrench might be a good thing to use on it as well.
