More done on 67'
zakt
More done on 67'
Post by zakt »
Well got the doors off most the inside removed. looks like I will replace the driver side floor board the passenger looks good. I have a 95' F350 Im using the motor, trans, transfer case from so thinking I might try to use that floor or some of both :D I want to use the linkage and shift lever for the transfer case off the 95' also so might make it easier by just using the whole floor in the front? I will be pulling the cab soon and the bed then pull the frame out and start preping to put the front leaf set up on (easier with everything else out of the way). Had one little issue with a door pin that was half way out (talk about a pain to get out to get the door off) used a screwdriver and a hammer to tap the pin the rest of the way, just have to fish for it in the pilar lower area now.....
Todd
drivers side:
passenger side:
more done:
1972 Ford F350 crewcab
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
man I love that triple-double drop roll bar!
that truck will be SWEET when you are done with it! good job!
In life many men take the path of righteousness, some take the path many others follow (G.M. owners, for example), some take a more arduous path, some a simpler path. I, sir, took the PSYCO-PATH!!
69F110
Post by 69F110 »
Zakt,
That doesn't look bad at all in there. The floor pans look solid.
That is one beautiful truck! Thanks for the update. I agree, that rollbar rocks!
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
zakt
re: More done on 67'
Post by zakt »
Its a rollbar for an 85' F350 and seems to fit, you know they wouldnt make anything like that for the old trucks :D the nerf bars I bought also are from an 87' F350 (crewcab) and I think I will have to do some cutting and welding, buying a set of 95' F350 (crewcab) nerf bars also they look to be shorter. The rear of the 67' cab is 6" shorter than the new trucks....
Todd
Sharkdance
Post by Sharkdance »
Damn that looks good!
Cant belive what good shape those floor pans are in. Nice truck! The roll bar sets it off too.
That truck is gonna come together nice. :clap:
Sharkdance
70 F250 2WD 360/C6
Big D's 69
Post by Big D's 69 »
I can't wait to see it when you get it finished. THe floor boards look good to me.
71 LONG BED
Post by 71 LONG BED »
Awesome job! I'd love to have crew myself someday. :D
John Member #1549
Image Image Image
67highboy
Post by 67highboy »
:eek: wow that truck is beautiful.
I wish mine was that clean :cry: :cry:
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
zakt
Post by zakt »
It was a california truck :D
