Various Capacities?
Clutch, transmission, rear axle
Drednme
Various Capacities?
Post by Drednme »
What are the front end, rear end, transfercase, and transmission capacitiees on these old beasts? Also what weights should be used? I was thinking 85-90 in all of them.
68 F-250, 4x4, 360, 4spd; BMW R1200C; 1995 jeep cherokee XJ RHD
4x4x4crewcab
re: Various Capacities?
Post by 4x4x4crewcab »
4spd manual and transfer case (from my owners manual 1970) above 10 deg--SAE50 oil----below 10deg---SAE30 OIL
If I remember correct Valvoline sold a straight 50 weight oil--thats what I used
Front and rear axle 80-90 should be fine
Steering knuckles---somewhere I had read 150 weight oil (can not find now) owners manual looks like its listed with the Conventional rear axle lube so 80-90w will work but if your wiper seals are shot it will run right back out and if thats the case and you dont want to fix right away the old timers said they just pumped grease in there. I used a current Ford lube sold at the dealers. I think it was like a 120 weight rear axle oil I will have to look in the garage but it was like 12.00 bucks a quart
as for the capacities go to the downloads on the home page of this site and click on the 1968 shop tips page. Page 3 on that will have all the capacities listed for your truck
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
willowbilly3
Post by willowbilly3 »
Good info. My 74 highboy had a doorjamb sticker that stated just what you said for the tranny, and the T-case too I think but different T-case use different oil. some use ATF. I also pumped gun grease into the front knuckles. I ilked the white Lubriplate but I think any chassis lube would work. It also has the added benafit of keeping out water if you have it packed full of grease.
heep70
Post by heep70 »
I have heard of people mixing gear oil and bearing grease together for knuckles.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
oldschoolrods
Re: re: Various Capacities?
Post by oldschoolrods »
heep70 wrote:I have heard of people mixing gear oil and bearing grease together for knuckles.
I DONT KNOW HOW ANYONE COULD STAND THE SMELL!!!!!
heep70
Post by heep70 »
It tasts better then it smells. :lol:
Greg
